Finished the Shackle flip....
Got drews kit. few loose pieces and the TG Creeper joint kit. First thing I noticed was that there would be no way to achieve the desired shackle angle with the outboarded peice being so far forward. I'll show you how I addressed this down below.
As a tip for removing the rivets, if the do not budge after 5 minutes of beating the fuck out of them then break out a drill and a good set of bits. drill the fuckers out starting small and working up to 1/2". I spent 2.5 hrs on the first side doing nothing but making a bunch of fucking noise. Next side I drilled 2 out of the 4 and it took 10 minutes.
Got everything welded up....
Had to trim the plate 2.5" (for bumper mounting bracket) and move the entire plate back about 2.5" from where Drew places it in order to achieve a tolerable shackle angle. 2.25" back would have been perfect.
I just drilled new holes in the frame and mounting bracket.
Gained about 1-2" of lift.
I cut the 6" shackles that Drew sent down to 4"......should have done 3" and may still swap them out to 3" shackles.
Angle is tolerable. It rides and flexes really well, much better than before with the bent, binding shackles. Love the feel of the truck.
Tires are still planted.
I gained a ton of down travel.......I would guess somewhere around 6". Much needed.
