Got a bunch more done this weekend.
I got the remaining tile up by my front door.
Took out the tile in the downstairs bathroom (it was barely mortared down and came up so easy).
I demoed the downstairs shower. This thing was leaking into the walls. They glued plastic sheets to the wall and then covered up the gaps with PVC trim and caulked it. Well the caulking failed years ago...
Cut out and threw away all of the ducting lines in the attic. It hurt to cut it out since the ducting still looked fine on the outside but as soon as I cut into it, I could see how nasty and dusty the lines were. I'm going to have my A/C guy come out and demo the upstairs furnace and outside fan. Its a 2014 R22 system and I'm going to replace everything since the house is gutted. I'm also changing the A/C return from a framed wall return (freaking nasty) to a ceiling return.
I climbed all over the attic and took out all the metal straps, old nails and anything sharp that can cut you.
I pulled out about 95% of the low voltage, alarm and coax line. It was a freaking rat's nest up there.
I demoed the kitchen and bathroom fur-downs so now these rooms feel way bigger. I have some good 2x4's from these fur-downs that I'm going to pull the nails out of to re-use on future walls. So that'll save me some money there.
While it was raining heavily this weekend, I discovered that the new deck they put in wasn't flashed properly against the house. So it looks like I might have to pull off the desk to re-flash it against the house now...But I'm not 100% certain that's what I'll have to do yet. I still need to demo the brick wall to get a better look at it. But there is boards against the house that I can stick my finger through.
And I discovered this gem while I was going through the attic
Maybe the house was wired by an electrician who used to be a plumber?
