Clean install!
Removing old wiring always makes me happy
I quickly looked for a square rocker switch that had the ON/OFF switch build into it like this: USB Car Charger Waterproof QC30 USB Charger Socket Power Outlet Adapter with On Off Switch LED Indicator for 12V24V Car RV ATV Boat Marine Motorcycle - Newegg.comI'll add fixing old wiring to the list. I went to add a single switch last night and ended up tearing out a lot of my old wiring to redo it.
Ever look at something on your truck and think "now who the F would do that." followed by "has anyone else ever worked on my truck in this area?" followed by "nope. how could I have been so lazy / dumb?"
Well, that was me last night. I honestly have no idea how it happened, but the mic for my head unit was tangled in with the grounding wire for the DVD player and USB power outlet. The grounding wires were somehow wrapped around the steering wheel column and had become disconnected from their grounding point. Not a big deal because the USB power was disconnected because I didn't like that the LED light was on all the time and the ground for the DVD just allows the video to play when the truck is in motion. But it was still embarassingly ugly.
While I was that deep in, I decided to install a push button OEM style Mictuning switch that has been sitting in my truck for probably at least 2 years.
I'll go snap a pic in a minute. But what wire to I tap into to get the switch to illuminate? Figure I can tap into a wire on the fog light switch. I think its the green/white wire that I have sort of separated from the pack. I see on TW that a lot of people do an add a fuse.
And I want to put the switch right above the USB ports. They are direct to the battery so that a phone can charge even when the truck is off. However, I don't want them on all the time. Having the switch will allow me to kill the power when not in use. Of course, that means I'm going to have to drill a hole after confirming there is nothing above it, but I'll cross that bridge later.
Ordered five 285/70/17 Toyo A/T III for my truck. Should be here in a week. I got the P rated tires as well to save money and weight bc Lord knows I won't have time to do any serious wheeling for the next few years with kids![]()
Been trying to do that for awhile now.I am going to need new tires soon for the Taco. I don't like them below 1/2 tread and I would bet they are below that. Upside is these will last me a lot longer since its not driven as much. I'm not buying shit until I get my wife gets the built-in closet organizer she wants. Those are like buying that STI Stacato XC. Just need to off my ass and get to it. I say that a lot it seems.
Yeah no need for thick sidewalls that will never see rocks. Just need em to hold up to curbs for the next few yearsI couldn't get myself to order the P rated ones. Though at the time I didn't know I'd be adding aftermarket wheels that weigh a shit ton.
Or do something like this? Sorry for the Tardworld link.Decided I need a way to carry my spare with me. 285s dont fit in the stock location and a rear bumper is out of the po picture for a good while. Thought about building a tire gate but decided on a "bed rack" carrier. Though it will be more like a shelf. Just flat across the bed rails, no rise. Want to avoid blocking all of the rear window and dont want to go the full height of the cab. Also decided that I dont want to bokt it to the bed rails because I want to be able to move it to any position depending on what else I'm carrying. So last night I played around with making a clamp that will hold it to the bed rails. Prototype #1 turned out decent but I built it upside down or backward or something. Anyway, the 2" angle should be on top with the weld on bottom. The angle going under the bed rail has a hole drilled in it and a 3/8" nut welded on to run bolts through and clamp it to the bed. Aside from drilling the holes on the wrong piece of angle I also didnt take into account the nuts being on there so I need to spread the two piece of angle a little further apart. I'll build up another one tonight and address these issues. Planning 4 of these clamps with 1.75" tubing running across the width of the bed. Thne tie the two bars together with some cross pieces and use a wheel hub I ordered on RockAuto for $16 as the tire mount. Just need to figure out a way to lock the tire to it because people suck. Thinking either take one of the studs out of the hub, replace it with a longer one, use an open ended lugnut and use a small padlock through a hole drilled in the stud. It just run a cable lock through the wheel and lock it to the bars. Probably the cable lock. I'm inky trying to keep out honest thieves. Ignore the shutty cuts and welds. It was just a rough prototype.
Ahh good to know. I haven't seen one in person yet.I've seen those in person and just don't like how much the tire moves on them. If I mounted a tire back there, I want it to be sturdy.
I would just run a cable through the wheel and around the bars.Decided I need a way to carry my spare with me. 285s dont fit in the stock location and a rear bumper is out of the po picture for a good while. Thought about building a tire gate but decided on a "bed rack" carrier. Though it will be more like a shelf. Just flat across the bed rails, no rise. Want to avoid blocking all of the rear window and dont want to go the full height of the cab. Also decided that I dont want to bokt it to the bed rails because I want to be able to move it to any position depending on what else I'm carrying. So last night I played around with making a clamp that will hold it to the bed rails. Prototype #1 turned out decent but I built it upside down or backward or something. Anyway, the 2" angle should be on top with the weld on bottom. The angle going under the bed rail has a hole drilled in it and a 3/8" nut welded on to run bolts through and clamp it to the bed. Aside from drilling the holes on the wrong piece of angle I also didnt take into account the nuts being on there so I need to spread the two piece of angle a little further apart. I'll build up another one tonight and address these issues. Planning 4 of these clamps with 1.75" tubing running across the width of the bed. Thne tie the two bars together with some cross pieces and use a wheel hub I ordered on RockAuto for $16 as the tire mount. Just need to figure out a way to lock the tire to it because people suck. Thinking either take one of the studs out of the hub, replace it with a longer one, use an open ended lugnut and use a small padlock through a hole drilled in the stud. It just run a cable lock through the wheel and lock it to the bars. Probably the cable lock. I'm inky trying to keep out honest thieves. Ignore the shutty cuts and welds. It was just a rough prototype.
