She gets good at those I will bring down my 4Runner for the same work. She like fancy juice boxes? Pretty sure the Boss Lady will not want me bringing her Fiesty Blonde.
Blower motor in Taco only had high and off... figured blower motor resister. Ordered a new one (OEM part) and I had Kenna swap it out. She fits under the dash better.Anyhow, not sure but it didn't fix the issue. I went and doubled checked the cannon plug an its snapped in place. Any ideas? I'm going to try and clean the cannon plug with electrical cleaner.... Update.. SUCCESS!
So both lower control arms have been replaced with brand new lowers. The FSM directions are a real kick in the nuts; but I found some directions that cut off a couple of hours. The 4Runner is now at the auto shop to steering rack replaced and then an alignment. Big props to Camelback Toyota for getting the parts to me as fast as they did. I ordered them late on Tuesday and they were delivered Thursday at 9:45 am.
I am going to keep the LCAs for TOR parts inventory. So the next 3rd gen that needs lower bushings swapped out can replace the bushings before taking off the lowers to save some wrench day time.
I did not have the proper fitting wrenches and the the ends were acting like they are seized. I went to mess with them before and had no luck.
Lol I have a spare set as well I bought cheap as CYASo both lower control arms have been replaced with brand new lowers. The FSM directions are a real kick in the nuts; but I found some directions that cut off a couple of hours. The 4Runner is now at the auto shop to steering rack replaced and then an alignment. Big props to Camelback Toyota for getting the parts to me as fast as they did. I ordered them late on Tuesday and they were delivered Thursday at 9:45 am.
Fuck changing the steering rack. That was the worst thing I've done on my Tacoma. I'd gladly pay someone to do it next time.
What a fucking pain in the ass. So I rewired the new horns, ran a new larger power wire to them from a Blue Sea fuse block (none of those old school glass fuses). Discovered that someone rigged a thin (18ga) wire from the column through the firewall and to the horns as the ground from the steering wheel. If I push on the horn button I can hear something making noise.... but its just a sort of clicking (larger horns probably require more juice). Maybe its broken down somewhere along the run. Ok, ran a new wire and it appears the horn button is intermittent. New one is on order should be here Monday. I cleaned up this one for now and if I push it "just right" and hold my tongue just so... it beeps. Well hey at least this should be the last time I fuck with it since I replaced everything in the system. LOL
Oh and also along with the horn button a K&N cleaning kit is arriving. This little fucker is nasty.
Reminds me the time I change all the trailer wire cause I had a short, which end up being a short in one those cheap brake light bulbs
It's only called maintenance before it breaks down. What happened anyways?Just had a bit of maintenance come up on the Tacoma. Nothing like breaking on the side of I10 outside Lafayette La. I had to muscle it 6 miles down the road to the dealer. I was lucky they were close. New front differential new OEM UCAs, and new CVS. Thank god Nathan had a a spare front diff and I had the UCAs. It was still a 1300 dollar tab.
Um no. HiLuxesor Navy SEALS.
