@tx_shooter loves welding upside down so he won't mind doing it.
Safety?? You mean leave the gas door open and spray some flammable solvents next to the welds to keep them cleanJust get a good welding blanket since welding next to a gas tank. #safetybitches
Thanks for the links. Saving em for future use!I'd drill it out completely and weld one of these in
Fix it Weld Washers, Set of 6
I have a pack of 50 of these I bought years ago and have found many uses for them over the years
McMaster-Carr
That's a Lotta work for a 30 seconds of weldingI have some welding blankets we can put around everything to keep it safe(er). But I would spend more time getting my welder setup in his garage then I would spend welding that in there. Overall not a hard project. @tex so when are we knocking this out?
If @taco4x4rar can cut your old Tacoma I am sure I can weld on your 4Runner.
. Sounds like something I would do in shorts and a pair a crocsHave you waterproofed the tent yet?So I finally got to the "mount RTT" part of my trip prep. I thought the backyard was dry enough to mount it like normal. I was pretty wrong on that and ended up using the Tred boards to get out. The only real take away is the Treds work and I now hate the Rock Mountain Matterhorn roof rack. The good news is this time next week I will be sitting around a camp fire in Big Bend Ranch State Park enjoying the weather and solitude.
Good!Did the method recommended by CVT and have never had a water issue.
While I was loading up for Big Bend tomorrow I had an idea on how to keep some of the loose items up out of the way and secured. A simple small string loop around the metal arm under the catch for the cargo cover. Overall it works pretty good but the bungee cord seems a little weak for a good restraint; I will have to keep working on that part. Maybe a shorter bungee.
Sbr is behind the driver seat. Lean driver seat forward, pull out negotiation stick, start talking.
Great idea for the bungee. Springtail makes some MOLLE panels that may help for side mounted tie downs. They have one that is 10.5 inches x 19 inches or one that is 8 inches x 6 inches.While I was loading up for Big Bend tomorrow I had an idea on how to keep some of the loose items up out of the way and secured. A simple small string loop around the metal arm under the catch for the cargo cover. Overall it works pretty good but the bungee cord seems a little weak for a good restraint; I will have to keep working on that part. Maybe a shorter bungee.
