Dad is waxing a few panels, then the rest is for the boy to finish up.
Before
Afta
I never had any luck with polishing the headlights. They would look good for a few months before going back or worse.
This helps, you can expect about 6months then repeat.
I made Logan wash/wax his own this weekend while I supervised lol
I did take it and had a Flowmaster put on it today for him.
You have to put a coat of wax on them after, and reapply on occasion. It's what we do on all of ours.
My boys washed the Laundry Fairys Lexy and my oldest boy waxed the entire suv. He did a fairly good job, really a great job, cause I didn't do it, lol
I got home and I washed and dryed da F150SCREW
Trailer lights were not working right on my 4Runner; which after some wire checking I noticed the previous owner spliced in the 4 way flat connector directly kind of into the factory plug. So I spent $20 to order a factory harness pigtail. Such a simple fix makes me laugh that they probably spent more time & money doing it the "cheap way".
Finally had a chance to swap that hose on the Ford. Didn’t work. It’s for a different style reservoir or something. Ended up putting the old quick connect fitting back on. I’ll just order a new o-ring for the quick connect fitting and if that doesn’t stop it, it can just leak until I trade it in.
Your reminder to check your tire pressure. One of my tires was at 18PSI (I normally run 36PSI with these tires).
Weird event tonight; I was replacing the u-joint in the rear part of the drive shaft. The ends on two end caps literally cracked and popped off when being seated. The pop was not even on the side where the pressure was being applied with the ball joint press. I have not seen this before but thankfully I have a spare u joint I keep in my camping parts kit. I will try on a different u-joint carrier tomorrow and hopefully be successful.
Anyone see that before? Did I just get some crap Spicer parts? Maybe fake Spicers?
