I'll sell them. They are fine.. just time for new ones.
Might have to.. I think I missed my window of opportunity. I got those two 6' medium ass fans out there now and I think if I can get it blown apart on Friday night (that shouldn't take too long) then on Saturday morning I can start reassembly and be done before it gets hot. Sounds good anyways.
I got my fronts swapped out in exactly 1 hour the other day. It helps that I have done about 10 front suspensions between mine and friends. 14mm, 17mm, 19mm, and 23mm for the LCA is all you should need.
Swanky
Oh I'm not worried about doing it... I know its very easy. My only "worry" is that the new reservoir mounts use the sway bar mounts... which I haven't used in years and don't have bolts too. So I'll have to dig up something.
Yeah, I got lucky and found my bolts in a box in my parts pile. I thought the same thing "Oh shit!"
I have extra bolts + relocation mounts with bolts I'm not using. They are red and from swayaway but will work. They are yours if you need them.
Thanks man! Any chance you can just get the size of them (thread pitch and length). I can probably get them local.
No problem, so long as remember tonight when I get home. Worst case have Roger remind me via text lol
I just called Toyota here in town and they can have them tomorrow and they are $1.99 a pop. Not bad IMO. So I went ahead and ordered them. Thanks anyhow Boyd.
Yea, snail mail would of cost more and taken longer. Good find.
Very true. I figured they would say "next week" or something. Shocked it was tomorrow.
Washed the Taco for the first time in... well I don't know when. Needed to get it clean before I pull the suspension off it. It needs a clay bar and some wax badly!!
Shocks cleaned up nicely.
4B20D140-0141-41F5-883C-C56D913CDA46.jpg~original
9433ED94-0D59-4913-8478-30809B49991C.jpg~original
8D0E9E08-2681-4CB9-98FE-32048510C31B.jpg~original
6A4A9A7F-C014-4E76-B9B8-ADF4CF057DAF.jpg~original
How did you manage to never destroy those lower shock mounts? Seems like they'd be a common issue for most people hanging down like that.
Yeah, they did. I know you travel at sub sonic but how bad was your passenger side shaft? Mine looked like it had been sandblasted... and, I guess it had been. :)
